After upgrading to 3.5.41, I get repeated crashes when I click on an album in album view. This is not sporadic, but almost every time. (With the way I use the program, this makes it almost impossible to use). This is the debug info.
Audirvana Mac Version 3.5.41 (3571)
macOS 10.15.7 with 24576MB RAM
Registered to xxxx
Replay Gain: by album
SW volume control: ON
Sync list: 3 folders
AUTO: /Volumes/Internal/Backup/Music/FLAC_WAV_ETC
AUTO: /Volumes/Internal/Backup/Music/Test CDs
AUTO: /Volumes/Internal/Backup/Music/iTunes/iTunes Media/Music
Library database path: /Users/xxx/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2830MB
Exclusive access: Disabled
Bifrost Gen 5
Model UID:Bifrost Gen 5:0D8C:0004
UID:AppleUSBAudioEngine:Schiit Audio:Bifrost Gen 5:14600000:1
ID 0x3b Bifrost Gen 5 Manufacturer:Schiit Audio
Model UID:Bifrost Gen 5:0D8C:0004 UID:AppleUSBAudioEngine:Schiit Audio:Bifrost Gen 5:14600000:1
Stream ID 0x3c 2 channels starting at 1
18 virtual formats:
24 physical formats
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:16 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x3b Bifrost Gen 5 Manufacturer: Schiit Audio Model UID: Bifrost Gen 5:0D8C:0004 UID: AppleUSBAudioEngine:Schiit Audio:Bifrost Gen 5:14600000:1
