Hi ,
Audirvana is no longer able to calculate ReplayGain for new albums that I add to my local library.
Thanks for your help
Audirvana Origin 3.1.0 (30100)
Running on GEEKOM Mini IT13
Windows 11 (26300) x86_64 with 32GB physical RAM
Connected account of : Jacques TROVEL
Available network interfaces:
Ethernet ({2d307ca9-a1a4-468b-85f8-e690f77d059b}) is PUBLIC
Windows Defender Firewall status for this instance of Audirvana Origin
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Wake-on-LAN: Ethernet ethernet 38:f7:cd:c6:65:01 enabled (the adapter’s magic-packet setting)
REMOTE CONTROL SERVER:
Listening on
2a01:e0a:82b:c2e0:5624:3363:6c9e:443a
192.168.1.122
on port 52442
LOADING/DECODING:
Max audio buffer size: 16384MB
Max zones supported: 8
Internal DSP option not present
PLUGINS: NOT ACTIVE
r8brain custom frequencies
44100Hz → 88200Hz
48000Hz → 96000Hz
Bandwidth = 90.6824%
Stop band attenuation 120.043dB
Replay Gain: by track
Volume step size: 1dB
AUTO: D:
Sync folders at startup: YES
Sort and display order: fr
Library database path: C:\Users\jacqu\AppData\Local\Packages\Audirvana.Audirvana-d488-4ebf-b1c4-596e08349a6a_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Font size: regular
Language: Langue du système
Bibliothèque
Favoris
Playlists
Startup view: Bibliothèque : Albums
Number of paired remotes: 0
Screen saver disabled: no
Max. memory for audio buffers: 16384MB
Kernel Streaming
Optimisation level: Extreme
Haut-parleurs (Liberty DAC II)
Model UID:USB\VID_25CE&PID_4C44&REV_0100&MI_00
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{e1feca7a-7a32-4ef0-aa63-8877f985aadb}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Selected device: Haut-parleurs (Liberty DAC II)
Manufacturer: Microsoft
Model name: Liberty DAC II
Model UID: USB\VID_25CE&PID_4C44&REV_0100&MI_00
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e1feca7a-7a32-4ef0-aa63-8877f985aadb}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Plays with Audirvāna: No
USB Vendor ID: 0x25ce
USB Product ID: 0x4c44
Kernel Streaming capable
MQA Decoder device
DSD via PCM 1.0
Channel 0: L
Channel 1: R
Simple stereo device: No
Device #0: Haut-parleurs (Liberty DAC II)
Bound interface: Ethernet ({2D307CA9-A1A4-468B-85F8-E690F77D059B}) 192.168.1.122:49154 [first physical NIC with IPv4]
Ethernet
Chromecast devices found : 1
Device #0: SONY XR-65A80L
Model name: BRAVIA 4K VH22
