Return to previous panel from setting
When I am in the settings there is no option to return to the panel that was displayed before entering these settings.
Hi @Jacek,
This is one of the limitation of the actual Remote app. We are preparing a major update and release it as a beta before the end of this year. You will be able to compare how it works when it will be available :slight_smile:
