I recently had an SSD crash on a Windows system that needed overhauling anyway. I completely replaced all components and rebuilt the PC. Unfortunately I cannot register Audirvana on it with the same licence code, and I cannot access the dead system to remove the licence from that. Might I suggest that the options in Audirvana include one to deauthorise both computers with the licence, so that if one is dead the other can be used to reclaim the licence code for it?
Hello @BaetisAudio,
I have removed all your computers from the license database. You can now activate up to two PC running Windows 10.
Currently we cannot do such things with Audirvana but we are working on a easier way to do this
Thank you very much! Sorry for the delay in responding I am going to check it out now.
