@Antoine If I revoke a license on a computer that I will be selling, how does that affect the actively used license on another computer? I’m guessing I just revoke the license on the computer I’m selling and remove the Audirvana app on the hard drive. Correct?
Paul
Hello @Champster,
If you remove the license key on one of your computer, it will not affect the other one.
You are right about it, you just need to do this and you will be able to use Audirvana on an other computer.
