What is the recommended method of ripping CDs to Audirvana?
Can Audirvana rip CDs directly? If not, should I use iTunes? XLD? Other software?
I have a dedicated (older) MacBook Pro dedicated to music, running Audirvana (trial) in standalone mode (without iTunes).
dabizi
October 4, 2019, 7:33pm
2
No, Audirvana doesn’t do this. You will need a separate application. I’m using dBpoweramp (https://dbpoweramp.com ). I also use it to convert between different format (E.g. convert highress flac to mp3 for on the go) and to edit meta-data. Works quite well for me.
I use XLD, and I’m very happy with it.
Thank you. Will check it out.
dBpoweramp
Hello,
after I bought Audirvana some time ago I would like to rip my old CD’s. I just downloaded dBpoweramp. Makes a great impression.
Two questions
which setting can you recommend if I want a really good quality but not too much memory
which standard hardware (CD player) works best for ripping? I only have one MacBookPro
Thanks a lot
system
Closed
December 22, 2022, 1:38pm
6
