Good evening everyone.
Iād like to try Audirvana, particularly to play (Octave Records) DSD recordings.
I want to download the DSD files on a
simple HP Windows10, i3, 8GB laptop and Iād install Audirvana on this device as well (cleaned it completely and reinstalled Windows).
I plan to connect the laptop via USB to my Audio Analogue AA DAC, which can play native DSD up to 512. My streamer (Innuos Pulse) is not compatible with Audirvana I thinkā¦
So an Audirvana rookie-user looking for some advice, tips, tricks and the like.
Thanks & all the best, Laurens
