I have a Mac running Audirvana 3.5. My music files also reside on the Mac. Initially I used Volumio with a RPI4 USB connected to a DB Lab DAC and then analogue to the receiver. Playback through computer or Audirvana remote was flawless. However I have since developed a problem with the DAC therefore I decided to purchase a HiFiBerry Digi2 Pro and connect it to the RPI4 which allowed me to connect my setup optically to the receiver and use its DAC. Since doing that I now get a “pause/skip” at the beginning of each songs playback. Can anyone suggest a cause/solution to this problem?
Hello @mozart,
Please remove the line corresponding to your logged-in account to avoid displaying your email address and first name/last name publicly.
Dear Antoine, I forgot to mention that I control the Audirvana app on my computer by using your Audirvana A+ remote. As I pointed out in the aforementioned problem while using the A+ remote I had no problem with the RPI4 alone with my DAC, I only developed the problem when I switched over to RPI4 + HiFiBerry. Therefore since I am using the remote how can I see the debug info?
You can’t, you need to go on your Mac to get it.
Dear Antoine, Here is the debug info you requested but first a couple of things. I went back to the USB DAC approach albeit with a borrowed DAC and it works fine. So, somewhere in the middle of the debug is when I had it running with the HiFi Berry attached if this means anything. Also I have to have the volume set low because my receiver’s zone two cannot handle the volume w/o popping. Don’t ask, there are a lot of problems I am working through with my system. I may soon be at the point where I will replace everything and start over. Otherwise let me know if the “debug” info shows anything.
debug info:
Per track: OFF
Max allowed volume: 47.3601
Replay Gain: by track
AUTO: /Users/scarp/Music/Music/Media.localized/Music
Library database path: /Users/scarp/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: Cambridge Model UID:Volumio Cambridge UID:uuid:90944204-e455-f98f-2925-dca632b97d4c
UPnP device at http://10.0.1.72:49152/description.xml
ID 0x0 Cambridge Manufacturer:Volumio
1 available sample rates up to 44100Hz
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::application/flac:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/mp1:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
1 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?>1
0
TransportState
no
string
STOPPED
PLAYING
TransportStatus
no
string
OK
ERROR_OCCURRED
PlaybackStorageMedium
no
string
PossiblePlaybackStorageMedia
no
string
RecordStorageMedium
no
string
PossibleRecordStorageMedia
no
string
CurrentPlayMode
no
string
NORMAL
SHUFFLE
REPEAT_ONE
REPEAT_ALL
RANDOM
DIRECT_1
NORMAL
TransportPlaySpeed
no
string
1
no
RecordMediumWriteStatus
string
CurrentRecordQualityMode
no
string
PossibleRecordQualityModes
no
string
NumberOfTracks
no
ui4
0
2000
1
CurrentTrack
no
ui4
0
2000
1
CurrentTrackDuration
no
string
CurrentMediaDuration
no
string
CurrentTrackMetaData
no
string
CurrentTrackURI
no
string
AVTransportURI
no
string
AVTransportURIMetaData
no
string
NextAVTransportURI
no
string
NextAVTransportURIMetaData
no
string
RelativeTimePosition
no
string
AbsoluteTimePosition
no
string
RelativeCounterPosition
no
i4
AbsoluteCounterPosition
no
i4
CurrentTransportActions
no
string
LastChange
yes
string
A_ARG_TYPE_SeekMode
no
string
ABS_TIME
REL_TIME
A_ARG_TYPE_SeekTarget
no
string
A_ARG_TYPE_InstanceID
no
ui4
SetAVTransportURI
InstanceID
in
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
RecordMedium
out
RecordStorageMedium
WriteStatus
out
GetTransportInfo
InstanceID
in
CurrentTransportState
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
TrackMetaData
out
TrackURI
out
CurrentTrackURI
RelTime
out
AbsTime
out
RelCount
out
AbsCount
out
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
RecMedia
out
RecQualityModes
out
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
Next
InstanceID
in
Previous
InstanceID
in
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
GetCurrentTransportActions
InstanceID
in
Actions
out
0
Cambridge
Volumio
The Audiophile Music Player
Volumio
1.0
42
image/png
64
64
32
/upmpd/icon.png
/upmpd/RenderingControl.xml
/ctl/RenderingControl
/evt/RenderingControl
/upmpd/AVTransport.xml
/ctl/AVTransport
/evt/AVTransport
/upmpd/ConnectionManager.xml
/ctl/ConnectionManager
/evt/ConnectionManager
urn:av-openhome-org:service:Product:1
urn:av-openhome-org:serviceId:Product
/upmpd/OHProduct.xml
/ctl/OHProduct
/evt/OHProduct
urn:av-openhome-org:service:Info:1
urn:av-openhome-org:serviceId:Info
/upmpd/OHInfo.xml
/ctl/OHInfo
/evt/OHInfo
urn:av-openhome-org:service:Time:1
urn:av-openhome-org:serviceId:Time
/upmpd/OHTime.xml
/ctl/OHTime
/evt/OHTime
urn:av-openhome-org:service:Volume:1
urn:av-openhome-org:serviceId:Volume
/upmpd/OHVolume.xml
/ctl/OHVolume
/evt/OHVolume
urn:av-openhome-org:service:Playlist:1
urn:av-openhome-org:serviceId:Playlist
/upmpd/OHPlaylist.xml
/ctl/OHPlaylist
/evt/OHPlaylist
urn:av-openhome-org:service:Radio:1
urn:av-openhome-org:serviceId:Radio
/upmpd/OHRadio.xml
/ctl/OHRadio
/evt/OHRadio
/upmpd/presentation.html
UPnP devices found : 1
Device #0: ID 0x0 Cambridge UID: uuid:90944204-e455-f98f-2925-dca632b97d4c Location: http://10.0.1.72:49152/description.xml
Device #0: ID 0x32 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:130 UID: AppleHDAEngineOutput:1F,3,0,1,2:0
Max. memory for audio buffers: 29696MB is to much. You must try a much lower setting of the socalled “memory for audio buffers”
Try something in between 1048 and 2048Mb
Your operating system will be much more happy and will react positive to it.
Succes
Dear Mollie, I can see how it will improve my OS but are you suggesting that it might solve the problem of why my songs “pause/skip” during playback?
You can always try. In any case, it can’t hurt.
Yep, probably it will solve your problem.
When most memory is in use for Audirvana, there is most of the time not enough left for proper functioning of the operating system, especially in case of havy o.s. trafic!!!
Anyway a try-out is costing nothing and could be reversed in case it does not help.
Succes, cheers and happy listening!!!
I took your rather good suggestion and attempted to try it. However, now I cannot get the HiFiBerry portion of the assembly to play at all. Seems I have bigger problems here. I may have to go with an all in one streamer. perhaps I have too many components in the equation (Mac computer running Audirvana through a RPI4 with a HiFiBerry Digi2 Pro playing through a Volumio encoded SD card connected to a Cambridge receiver).
I see at your debug info that you seems to be using Volumio 1.0 which is very old.
At the moment Volumio software is up to version 2.9.15 !!!
Please update the rpi/volumio software to the latest version when the above is true!!!
How are you controlling the audio volume? By Audirvana, by Volumio, or by your receiver?
Do i understand right that you connect the rpi/dac (fixed) analog outputs to your receiver?
By which way is the output from your computer connected to the rpi/dac?
Hopefully we can figure out what the real problem is.
Cheers, mollie
It seems that using the hifiberry OS loaded onto the SD card is friendly to Roon however not to Audirvana which would explain why playback creates issues. Whereas Volumio loaded onto the SD card is friendly to Audirvana but not to hifiberry. This would explain why Audirvana plays through RPI with Volumio but not through hifiberry berry with hifiberry OS. What I’m trying to do now is to see if there is a work -a-round to get HiFiBerry to use Volumio. This would allow me to use the optical out on the HiFiBerry without having to change over to Roon.
