Bonjour, ci-dessous le debug correspondant édité immédiatement après l’évènement
Audirvana Studio 1.8.5 (10805)
Windows 11 (22000) with 16GB physical RAM
SW volume control: ON
Sync list: 3 folders
AUTO: F:\Musique\CD
AUTO: F:\Musique\DSD
AUTO: F:\Musique\HiRes Music
Library database path: C:\Users\mouni\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2a01:e0a:84d:7310:f5b1:c6b5:30e4:3cee on port 51181
Preferred device: TEAC Corporation TEAC NT-505:TEAC Model UID:TEAC Corporation TEAC NT-505:TEAC UID:uuid:4c494e4e-3d9b-11e1-b86c-0016e867f96f
Currently playing to UPnP device at 24 bits 96kHz
UPnP device at http://192.168.1.46:23000/
TEAC NT-505:TEAC
Manufacturer: TEAC Corporation
Model Name:
Model UID: TEAC Corporation TEAC NT-505:TEAC
UID: uuid:4c494e4e-3d9b-11e1-b86c-0016e867f96f
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: No
http-get:::*
http-get::audio/mpeg:
http-get::audio/mpeg3:
http-get::audio/mp3:
http-get::audio/x-mp3:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/mp4:
http-get::audio/mpeg4-generic:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aac:
http-get::audio/alac:
http-get::audio/x-alac:
http-get::audio/dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::application/octet-stream:
DLNA 1.5: Yes
Gapless playback: No
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB
NrTracks: 1
MediaDuration: 00:04:03
CurrentURI: http://192.168.1.115:49152/audirvana/audio_0.wav
CurrentURIMetadata:
dc:titleTrouble with My Lover</dc:title>
dc:creatorRobert Plant</dc:creator>
upnp:artistRobert Plant</upnp:artist>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/uc/n8/g212ahj63n8uc_600.jpg</upnp:albumArtURI>
upnp:albumRaise The Roof </upnp:album>
upnp:originalTrackNumber4</upnp:originalTrackNumber>
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Next InstanceID in A_ARG_TYPE_InstanceID Pause InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Previous InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID CurrentPlayMode string NORMAL NORMAL REPEAT_ONE REPEAT_ALL SHUFFLE SHUFFLE_NOREPEAT RecordStorageMedium string NOT_IMPLEMENTED LastChange string RelativeTimePosition string CurrentTrackURI string CurrentTrackDuration string CurrentRecordQualityMode string NOT_IMPLEMENTED CurrentMediaDuration string AbsoluteCounterPosition i4 RelativeCounterPosition i4 A_ARG_TYPE_InstanceID ui4 AVTransportURI string TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING NO_MEDIA_PRESENT CurrentTrackMetaData string NextAVTransportURI string PossibleRecordQualityModes string NOT_IMPLEMENTED CurrentTrack ui4 0 65535 1 AbsoluteTimePosition string NextAVTransportURIMetaData string PlaybackStorageMedium string NONE UNKNOWN CD-DA HDD NETWORK CurrentTransportActions string RecordMediumWriteStatus string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string NONE UNKNOWN CD-DA HDD NETWORK AVTransportURIMetaData string NumberOfTracks ui4 0 65535 A_ARG_TYPE_SeekMode string REL_TIME TRACK_NR A_ARG_TYPE_SeekTarget string PossibleRecordStorageMedia string NOT_IMPLEMENTED TransportStatus string OK ERROR_OCCURRED TransportPlaySpeed string 1Current device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 TEAC NT-505:TEAC TEAC Corporation http://audio.teac.com/ TEAC TEAC 1.0 http://audio.teac.com/ uuid:4c494e4e-3d9b-11e1-b86c-0016e867f96f DMR-1.50 image/png 120 120 24 /images/lumin-120x120.png image/png 48 48 24 /images/lumin-48x48.png urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/4c494e4e-3d9b-11e1-b86c-0016e867f96f/scpd.xml /AVTransport/4c494e4e-3d9b-11e1-b86c-0016e867f96f/control.xml /AVTransport/4c494e4e-3d9b-11e1-b86c-0016e867f96f/event.xml urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e867f96f/scpd.xml /ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e867f96f/control.xml /ConnectionManager/4c494e4e-3d9b-11e1-b86c-0016e867f96f/event.xml urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e867f96f/scpd.xml /RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e867f96f/control.xml /RenderingControl/4c494e4e-3d9b-11e1-b86c-0016e867f96f/event.xml urn:av-openhome-org:service:Product:1 urn:av-openhome-org:serviceId:Product /Product/4c494e4e-3d9b-11e1-b86c-0016e867f96f/scpd.xml /Product/4c494e4e-3d9b-11e1-b86c-0016e867f96f/control.xml /Product/4c494e4e-3d9b-11e1-b86c-0016e867f96f/event.xml urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /Playlist/4c494e4e-3d9b-11e1-b86c-0016e867f96f/scpd.xml /Playlist/4c494e4e-3d9b-11e1-b86c-0016e867f96f/control.xml /Playlist/4c494e4e-3d9b-11e1-b86c-0016e867f96f/event.xml urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /Time/4c494e4e-3d9b-11e1-b86c-0016e867f96f/scpd.xml /Time/4c494e4e-3d9b-11e1-b86c-0016e867f96f/control.xml /Time/4c494e4e-3d9b-11e1-b86c-0016e867f96f/event.xml urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /Info/4c494e4e-3d9b-11e1-b86c-0016e867f96f/scpd.xml /Info/4c494e4e-3d9b-11e1-b86c-0016e867f96f/control.xml /Info/4c494e4e-3d9b-11e1-b86c-0016e867f96f/event.xml urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /Volume/4c494e4e-3d9b-11e1-b86c-0016e867f96f/scpd.xml /Volume/4c494e4e-3d9b-11e1-b86c-0016e867f96f/control.xml /Volume/4c494e4e-3d9b-11e1-b86c-0016e867f96f/event.xml urn:av-openhome-org:service:Transport:1 urn:av-openhome-org:serviceId:Transport /Transport/4c494e4e-3d9b-11e1-b86c-0016e867f96f/scpd.xml /Transport/4c494e4e-3d9b-11e1-b86c-0016e867f96f/control.xml /Transport/4c494e4e-3d9b-11e1-b86c-0016e867f96f/event.xml urn:magictv-com:service:MagicAudio:1 urn:magictv-com:serviceId:MagicAudio /MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e867f96f/scpd.xml /MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e867f96f/control.xml /MagicAudio/4c494e4e-3d9b-11e1-b86c-0016e867f96f/event.xml urn:av-openhome-org:service:Credentials:1 urn:av-openhome-org:serviceId:Credentials /Credentials/4c494e4e-3d9b-11e1-b86c-0016e867f96f/scpd.xml /Credentials/4c494e4e-3d9b-11e1-b86c-0016e867f96f/control.xml /Credentials/4c494e4e-3d9b-11e1-b86c-0016e867f96f/event.xml urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /Radio/4c494e4e-3d9b-11e1-b86c-0016e867f96f/scpd.xml /Radio/4c494e4e-3d9b-11e1-b86c-0016e867f96f/control.xml /Radio/4c494e4e-3d9b-11e1-b86c-0016e867f96f/event.xml urn:av-openhome-org:service:Receiver:1 urn:av-openhome-org:serviceId:Receiver /Receiver/4c494e4e-3d9b-11e1-b86c-0016e867f96f/scpd.xml /Receiver/4c494e4e-3d9b-11e1-b86c-0016e867f96f/control.xml /Receiver/4c494e4e-3d9b-11e1-b86c-0016e867f96f/event.xmlUPnP devices found : 1
Device #0TEAC NT-505:TEAC UID: uuid:4c494e4e-3d9b-11e1-b86c-0016e867f96f Location: http://192.168.1.46:23000/
Max. memory for audio buffers: 5450MB
Local Audio Engine: WASAPI
Device #0: Haut-parleurs (Realtek(R) Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{543bdba3-7c8c-466f-a424-7564377273f5}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Haut-parleurs (Realtek(R) Audio)
