Sample Rate Not Changing
Hi, my RME ADI-2 DAC FS is set to 192kHz. My PC is also set to 192kHz. When I play a song in Audirvana that is for example, 44.1kHz, my DAC is still displaying 192kHz. Audirvana is not automatically switching my sample rate dependent on the sample rate of the song that is playing. Is there a way to fix this? Thanks.
Version: 2.3.0 (20300) and on Wasapi.
Mike
Hi @mdepalma , could you please post up your debug report so that the community can see what your settings are?
Welcome to the community
Audirvana Studio 2.3.0 (20300)
Windows 11 (22621) with 64GB physical RAM
Connected account of : Michael DePalma
	VST3 plugin #0: C:\Program Files\Common Files\VST3\FabFilter Pro-Q 3.vst3
		ClassID: 72C4DB717A4D459AB97E51745D84B39D
	VST3 plugin #1: None
	VST3 plugin #2: None
	VST3 plugin #3: None
Sync list: 0 folders
Library database path: C:\Users\Michael\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 3393
Listening on 2603:8000:a200:9513:e3d8:9edd:556d:12b on port 6874
Max. memory for audio buffers: 35260MB
Local Audio Engine: WASAPI
Analog (1+2) (RME ADI-2 DAC)
Model UID:USB\VID_2A39&PID_3FD3&REV_0001
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{3ad3b0ae-6d71-4b95-ab98-05ee85efa3e9}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 24bits Integer, 8 bytes per frame 192kHz
Active Sample Rate: 192kHz
Selected device:Analog (1+2) (RME ADI-2 DAC)
Manufacturer: RME
Model name: ADI-2 DAC (51080015)
Model UID: USB\VID_2A39&PID_3FD3&REV_0001
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{3ad3b0ae-6d71-4b95-ab98-05ee85efa3e9}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x2a39
USB Product ID: 0x3fd3
1 available sample rates up to 192000Hz
Simple stereo device: No
Local devices found : 6
Device #0: PA32UCG (NVIDIA High Definition Audio)
Manufacturer: NVIDIA
Model UID: HDAUDIO\FUNC_01&VEN_10DE&DEV_00A3&SUBSYS_10DE165B&REV_1001
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{dba0972e-9532-47fd-ac56-9d689a81b99a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (Steam Streaming Speakers)
Manufacturer: Valve Corporation Audio DDK
Model UID: ROOT\SteamStreamingSpeakers
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ab53ab4f-23c9-4176-8fdc-3f00674e6f78}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Unknown model
Device #2: Analog (1+2) (RME ADI-2 DAC)
Manufacturer: RME
Device #3: Headphones (2- AT2020USB+)
Manufacturer: (Generic USB Audio)
Model UID: USB\VID_0909&PID_001C&REV_0100&MI_00
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{cedfa573-4a0a-4305-9429-c325f43a259b}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x0909
USB Product ID: 0x001c
Model name: AT2020USB+
Device #4: Speakers (Steam Streaming Microphone)
Model UID: ROOT\SteamStreamingMicrophone
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{116e3515-95ae-425f-97a9-cb1baa843295}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #5: VG28UQL1A (NVIDIA High Definition Audio)
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{042183b2-61c1-4148-8580-07098854339b}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Is your dac set to this sample rate only or it is its max?
You can turn off plugin to test if it is it… that bug…
My dac is set to 192kHz. I have the RME MADI interface which allows me to control the sample rate on the dac. Right now it is set to 192.
Just a quick look on my part, you have set everything to upsampling at 192 ?
Can you change to no upsampling?
I turned off the plugin but it still getting upsampled-
Clicking on the cog wheel I am looking at this in the upsampling window. It says it’s deactivated I’m so confused haha-
Thanks for jumping in RHS :+1:t2: Going to dinner in a few minutes.
Only available sample rate?
Something about that
Yeah it doesn’t let me select any other PCM or DSD option. Also everything is greyed out (can’t be changed) in the Dac Input window-
Not upsampling in audirvana, that looks ok,
but your dac is set to 192 only??
can you set it up to nothing, and let the software manage the sample rate :grinning:
Not knowledgeable with your dac and windows, but surely not looking at audirvana fault as i understand that debug,… not even good at reading that, just giving you hints… :grinning:
Like set the DAC to native no internal upsampling. Maybe :thinking:
soooo sick got it working now, turns out being on Wasapi was the issue. I guess the RME Madi interface only likes to work with ASIO. It’s changing the sample rates automatically.
Thanks guys!
