How come the sample rates do not match between A+ and DAC? I have the up-sampling function turned off.
Its random, with the new Prince album, it says Tidal Flac 24/192kHz > DAC side it says 24/96kHz. My DAC is more than capable of 192kHz.
Also with many Masters albums, it says Tidal Flac 24/44.1 > DAC side it says 24/88.2kHz?
With Tori Amos it says Tidal Flac 24/96kHz > DAC side it also says 24/96kHz.
Hi Adamn, I’m also trying to wondering how Audirvana deals with MQA.
Did you got some support on it?
It’s totally not related with Tidal. I made several tests, playing locals files in my computer.
Here some results:
MQA FLAC 24/352.8 -> DAC 24/88.2 (4/1)
MQA FLAC 24/96 -> DAC 24/96 (1/1)
MQA FLAC/44.1 -> DAC 24/88.2 (1/2)
I’m new here, but now I understood why it’s limited up to 96kHz, from this article here:
“…software decoding is limited to a maximum sample rate of 96kHz. Files that were originally at 176.4kHz, 192kHz, or 384kHz will unwrap only to a maximum of 96kHz, not the original sample rate. There is no such limitation with an MQA-equipped DAC.”
source: http://www.theabsolutesound.com/articles/mqas-unexpected-twist/
Question solved Adamn.
