Hi, I have an Android, I purchased the Audirvana Remote from the play store.
Works fine for a while , then it prompts me and says I need to buy it from the play store…
When I am using it, I am connected to a wireless router, NO internet.
My MacBook is on the same wireless network, no internet…
The Audirvana app on it never complains about license…
Sounds like this Android application is pinging you to see if it is licensed when using it
and needs internet access…
I need to be able to use the Remote app without any internet.
Please advise.
