Schiit Gungnir won't DSD
Been using a FIIO dac for a few mo, no issues with PCM or DSD. So ā€œupgradedā€ to the Gungnir, sigma delta version but with Unison USB upgrade. Basically, PCM upsampling works great, but can’t get it for DSD in any way via usb- silent no sound. Have tried every setting combo I can conceive of, no dice. Strangely, on an OLD imac I can get the DSD to show up but the DAC clicks out soon as the track tries to start. With newer MBP, DSD does not even show up. ā€œDSD over PCMā€ yes, but not in the actual upsampling settings. Have tried 3 usb cables. Thanks for any help here.
Welcome…
The Schiit Audio DACs do not handle 1-bit PDM (DSD) they only handle multi-bit PCM… In your case:
GUNGNIR 2
BALANCED MULTIFORMā„¢ DAC
Input Capability
  • Up to 32/384 for Unison 384
  • Up to 32/192 for other inputs
You will need to set the ā€œNative DSD streaming methodā€ to: ā€˜None, convert to PCM’
Ah, I see. Well I won’t miss it, it sounds amazing. Thanks for setting me straight.
