Hi,
The search engine does not return the artists when searching, even with exact spelling.
See screenshot for example.
Hello @JamesG, can you check the metadata of the Doors in Audirvana? Do you have the Sort as filed filled? To do this, go in the Artist tab of Audirvana in your Library, select The Doors and open the metadata panel to check what do you have.
Weirdly I added a new album and now, the search works properly. I don’t really understand how this is possible but it seems to be fixed. Thanks
