There needs to be a way to point to the VST folder you want load plugins from. I produce music and have a million plugins in a bunch of different folders. It takes five minutes at least to start Audirvana because it has to search for plugins in so many folders. If I turn off vst processing the app loads very quickly.
You get to point to the Local Music folders you want to use. I don’t get why this is not the same for VST’s.
If there is a way to do this and I’m missing something please let me know.
Audirvāna on Windows is only compatible with VST3 plugins, you then do not have to put the plugin on a folder this the folder is by default always the same for VST3 plugins.
Understood. I do have hundreds of vst3 plugins so it’s still makes it take forever to load. Would it be possible to specify a folder within the CommonFiles/VST3 folder for Audirvana so that I can avoid this?
