Hi there.
I’m using Audirvana on a Windows 10 tablet. What are the best settings? I have a Arcam Solo Music and a Qobuz Sublime license.
Hello @hjs,
Enable DLNA in the setting and try to stream to it from Audirvana.
Hi Damian,
Thanks for your reply.
Here is the info You asked for:
What happens is sometimes a faltering sound. And I can’t find a setting for gapless playback.
Audirvana 3.5.37
SW volume control: ON
AUTO: \swnas\music\losless
Library database path: C:\Users\Pc\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as Qobuz Hi-Fi Sublime
Max. memory for audio buffers: 2834MB
Local Audio Engine:WASAPI
Arcam Solo Music
Model UID:A & R Cambridge Arcam Solo Music
UID:uuid:140479c0-58f3-1cef-84bf-001b7c054ba6
Active Sample Rate: 48kHz
Speakers (2- Realtek High Definition Audio) Manufacturer:
Model UID:Speakers (2- Realtek High Definition Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{042ae09f-3199-4fbf-a516-b948a9dd528a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
4 available sample rates up to 192000Hz
Simple stereo device: No
Device #0: Speakers (2- Realtek High Definition Audio) Manufacturer: Model UID: Speakers (2- Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{042ae09f-3199-4fbf-a516-b948a9dd528a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (USB Audio) Manufacturer: Model UID: Speakers (USB Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{043bf54a-5512-4b4f-b347-d89540df6465}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 2
Device #0werkkamer UID: uuid:9ab0c000-f668-11de-9976-00a0def7dbd1 Location: http://192.168.178.45:49154/MediaRenderer/desc.xml
Device #1werkkamer UID: uuid:9ab0c000-f668-11de-9976-00a0def7dbb6 Location: http://192.168.178.44:49154/MediaRenderer/desc.xml
I can see the debug info have the information of your DAC but it doesn’t see it connected, can you make sure you can select it in Audirvana?
hi,
I pasted the info another time with the Arcam switched on and connected.
Audirvana 3.5.38
Preferred device: Arcam Solo Music Model UID:A & R Cambridge Arcam Solo Music UID:uuid:140479c0-58f3-1cef-84bf-001b7c054ba6
UPnP device at http://192.168.178.91:2870/dmr.xml
Arcam Solo Music Manufacturer:A & R Cambridge
Volume control: No
http-get::image/jpeg:DLNA.ORG_PN=JPEG_SM
http-get::image/png:DLNA.ORG_PN=PNG_LRG
http-get::image/jpeg:DLNA.ORG_PN=JPEG_MED
http-get::image/jpeg:DLNA.ORG_PN=JPEG_LRG
http-get::video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL
http-get::video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO
http-get::video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO
http-get::video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO
http-get::video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO
http-get::video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO
http-get::video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC
http-get::video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC_XAC3
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T
http-get::video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T
http-get::video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE
http-get::image/vnd.ms-photo:
http-get::image/gif:
http-get::image/x-ycbcr-yuv420:
http-get::image/mpo:
http-get::image/x-icon:
http-get::image/x-quicktime:
http-get::image/jpe:
http-get::audio/L8:
http-get::audio/mp1:
http-get::audio/mp2:
http-get::audio/basic:
http-get::audio/aiff:
http-get::audio/mid:
http-get::audio/x-ms-wax:
http-get::audio/wav:
http-get::audio/vnd.rn-realaudio:
http-get::audio/x-mpegurl:
http-get::audio/x-wav:
http-get::audio/x-flac:
http-get::audio/x-m4a:
http-get::audio/x-ms-wmv:
http-get::audio/x-ogg:
http-get::audio/midi:
http-get::audio/x-aac:
http-get::audio/x-ac3:
http-get::audio/x-atrac3:
http-get::audio/x-dts:
http-get::audio/x-pn-realaudio:
http-get::audio/x-quicktime:
http-get::audio/dolby:
http-get::audio/adts:
http-get::audio/3gpp:
http-get::audio/sonyoma:
http-get::video/3gpp:
http-get::video/mp2p:
http-get::video/mpeg2:
http-get::video/quicktime:
http-get::video/x-dv:
http-get::video/x-motion-jpeg:
http-get::video/x-nerodigital-ps:
http-get::video/mp1s:
http-get::video/tts:
http-get::video/x-msvideo:
http-get::video/divx:
http-get::video/xiid:
http-get::video/asf:
http-get::video/wmv:
http-get::video/x-matroska:
http-get::video/rtml:
http-get::video/x-ms-wmx:
http-get::video/x-ms-wm:
http-get::video/x-ms-asf:
http-get::video/x-ms-wvx:
http-get::video/x-ms-dvr:
http-get::video/avi:
http-get::video/vnd.rn-realvideo:
http-get::video/x-pn-realmedia:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
NrTracks: 0
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI: NOT_IMPLEMENTED
PlayMedium: NONE
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportStatus string OK ERROR_OCCURRED NextAVTransportURI string NextAVTransportURIMetaData string CurrentTrackMetaData string RelativeCounterPosition i4 A_ARG_TYPE_InstanceID ui4 A_ARG_TYPE_SeekTarget string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED RelativeTimePosition string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL REPEAT_ALL INTRO NORMAL TransportPlaySpeed string 1 PossiblePlaybackStorageMedia string AbsoluteTimePosition string CurrentTrack ui4 0 4294967295 1 CurrentTrackURI string NumberOfTracks ui4 0 4294967295 AVTransportURI string AbsoluteCounterPosition i4 CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED CurrentMediaDuration string CurrentTransportActions string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME AVTransportURIMetaData string RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED LastChange string CurrentTrackDuration string TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT PossibleRecordQualityModes stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 Arcam Solo Music A & R Cambridge http://www.arcam.co.uk/ HtiB Arcam Solo Music 1.0 http://www.arcamradio.co.uk/ uuid:140479c0-58f3-1cef-84bf-001b7c054ba6 image/png 48 48 24 /icon/DMR-small.png image/png 120 120 24 /icon/DMR-large.png image/jpeg 48 48 24 /icon/DMR-small.jpg image/jpeg 120 120 24 /icon/DMR-large.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /dmr_rcs.xml control/RenderingControl event/RenderingControl urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /dmr_cms.xml control/ConnectionManager event/ConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /dmr_avts.xml control/AVTransport event/AVTransportUPnP devices found : 3
Device #1Arcam Solo Music UID: uuid:140479c0-58f3-1cef-84bf-001b7c054ba6 Location: http://192.168.178.91:2870/dmr.xml
Device #2werkkamer UID: uuid:9ab0c000-f668-11de-9976-00a0def7dbb6 Location: http://192.168.178.44:49154/MediaRenderer/desc.xml
Hello @hjs,
You can try to enable upsampling in the audio output settings in Audirvana. When you have more than a track in your play queue, does it goes to the next track?
Hi,
Most of the time it goes to the next track on the playlist. Wich choice is the best when upsampling is enabled? “Device maximum frequency”?
You can start with “Power of 2” then if it’s working you can try “Device maximum frequency” but if you have playback issue with either of those settings you will have to disable upsampling.
