Hi, I’m new here and do hope not to repeat already known issue. I’ve just configured the following system to play HiRez files: Mac mini (2018 - 3.0GHz 6-core Intel Core i5, 8GB RAM) with Audirvana Studio trial software and Mytek Liberty DAC with firmware version 1.35 (manual: https://mytek.audio/web/content/2130?unique=6aa8ac4c2933572905b7bee3f340d5a6f73a8040&download=true) interconnected via USB port. I downloaded some DSD files with various resolutions (64/128/256). Everything works fine with DoP 1.1 option selected in Audirvana except DSD256 format playback, which gets converted into PCM. To me all such tracks are loosing a bit of brightness and punch. One can listen to jazz with pleasure but for instance rock bands sound somehow not convincing (a subjective judgement of course).
Below is debug info taken while playing DSD256.
Is there anything I could improve in Audirvana settings to enjoy pure DSD256 format end-to-end?
Thank you!
Audirvana Studio 1.14.0 (11400)
macOS Version 12.6 (Build 21G115) with 8GB physical RAM
Connected account of : Przemyslaw
Sync list: 2 folders
AUTO: /Users/przemek/Documents/Muzyka HD
AUTO: /Users/przemek/Music
iTunes/Music library synchronization: last synchronized on Tue Sep 20 16:51:40 2022
Library database path: /Users/przemek/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49872
MYTEK DIGITAL LIBERTY DAC
Model UID:Liberty DAC:25CE:001E
UID:AppleUSBAudioEngine:Mytek Digital:Liberty DAC:HEM006499:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 352.8kHz
Active Sample Rate: 352.8kHz
Hog Mode is on
ID 0x4e Liberty DAC
Manufacturer: Mytek Digital
Model Name: Mytek Digital Liberty DAC
Model UID: Liberty DAC:25CE:001E
UID: AppleUSBAudioEngine:Mytek Digital:Liberty DAC:HEM006499:1
Stream ID 0x4f 2 channels starting at 1
24 virtual formats:
32 physical formats
Device #0: ID 0x4e Liberty DAC Manufacturer: Mytek Digital Model UID: Liberty DAC:25CE:001E UID: AppleUSBAudioEngine:Mytek Digital:Liberty DAC:HEM006499:1 Model Name: Mytek Digital Liberty DAC
Device #1: ID 0x48 Głośniki (Mac mini) Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Głośniki (Mac mini)
