Hello!
I understand that each audio player is configured to sound its best. I imagine this is true for Audirvana+. What settings can I use to disable all features that modify the audio in any way? The application at this point seems to enhance the higher frequencies. I did not discover this until the trial ran out, and I was forced to use the app from Qobuz. I originally thought this was a problem with the specific brand of headphones that I use. Apparently not. I had to apply de-emphasis by using an EQ.
Thank you!
Bob Graham
