If you put contains iTunes Music in the cirteria, do you see something in the smartplaylist?
No, it doesn’t change anything, the list remains empty.
I specify that my iTunes library folder and thus the iTunes Music folder are on an internal disk, in my user folder bis, which is not the system disk, I do not know if it is important. In any case, it doesn’t prevent everything else from working normally.
Great advice!
I was able to create a random playlist!
