Per title the ‘Browse similar artists’ feature no longer works for me - not sure when this stopped working.
When I press the little graphic the window above the artist opens and says loading - then there is nothing displayed in the window (ie no similar artists list).
This feature works in the Tidal desktop app and Roon.
I tried deleting the Audirvana ‘plist’ file and A+ itself - then reinstalling. Doesn’t fix the problem. Any ideas?
I’m using the latest 3.2.13 version of A+ on a Mac mini running Mojave 10.14.1
Went through and trashed all caches and files relating to Audirvana - still no luck, cannot get get the ‘Similar artists/Influenced by’ lists to appear.
Like I said the dropdown window opens, just nothing in it.
I went back to my old Mac mini, which runs High Sierra 10.13.6 and A+3.2.6 - but this behaves the same as above.
Obviously this is a Tidal feature and something many people would use, can anyone confirm this still works in Audirvana?
If so, can anyone suggest a fix?
I’ve just released 3.2.14 that fixes this issue.
You can use the “Check for updates…” command of the Audirvana Plus menu to get it.
Yep, confirmed working now with 3.2.14.
Thanks for the great service Damien!
