When streaming from Qobuz with 192 kHz/24 bits, or even when reading files bought on Qobuz with this Hi-Res quality, I have some sizzling, sometimes strong.
My DAC is able to handle such Hi-Res quality files (the screen indicates 192 kHz is recognized).
My Qobuz subscription is Hi-Res 192 kHz.
As soon as I change the frequency target to 96 kHZ in Audirvana, there is no more sizzling.
Please see attached debug info.
What could be done to avoid this ?
macOS 11.2.3 with 8192MB RAM
Licence enregistrée pour Philippe HENNERON
SoX custom frequencies
Phase = 65
SW volume control: ON
AUTO: /Volumes/WD 2TB/Philippe/Music/Musique Philippe
Library database path: /Users/philippehenneron/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 6596MB
PX1 Asynchronous X-MOS - USB B
Model UID:PX1 Asynchronous X-MOS - USB B:20B1:0002
UID:AppleUSBAudioEngine:PX1 :PX1 Asynchronous X-MOS - USB B:0000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 192kHz
Active Sample Rate: 192kHz
Hog Mode is on
ID 0x58 PX1 Asynchronous X-MOS - USB B Manufacturer:PX1
Model UID:PX1 Asynchronous X-MOS - USB B:20B1:0002 UID:AppleUSBAudioEngine:PX1 :PX1 Asynchronous X-MOS - USB B:0000:1
Stream ID 0x59 2 channels starting at 1
12 virtual formats:
12 physical formats
Device #0: ID 0x58 PX1 Asynchronous X-MOS - USB B Manufacturer: PX1 Model UID: PX1 Asynchronous X-MOS - USB B:20B1:0002 UID: AppleUSBAudioEngine:PX1 :PX1 Asynchronous X-MOS - USB B:0000:1
Device #1: ID 0x4c Haut-parleurs MacBook Air Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
