I am using Audirvana on a brand new Mac Book Pro, but when I play SACD, it often skips like it has to buffer. Is there a setting that I can improve this condition?
Here is my debug info…
Audirvana Studio 1.8.5 (10805)
macOS 12.0.1 with 8GB physical RAM
Per track: OFF
AUTO: /Volumes/Music 5tb/Music
Library database path: /Users/kevin/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 57551
Max. memory for audio buffers: 5188MB
TOPPING D90SE
Model UID:D90SE:152A:8750
UID:AppleUSBAudioEngine:Topping:D90SE:1110000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 352.8kHz
Active Sample Rate: 352.8kHz
Hog Mode is on
ID 0x64 D90SE
Manufacturer: Topping
Model Name: Topping D90SE
Model UID: D90SE:152A:8750
UID: AppleUSBAudioEngine:Topping:D90SE:110000:1
MQA Decoder device
Stream ID 0x65 2 channels starting at 1
30 virtual formats:
40 physical formats
Device #0: ID 0x64 D90SE Manufacturer: Topping Model UID: D90SE:152A:8750 UID: AppleUSBAudioEngine:Topping:D90SE:110000:1 Model Name: Topping D90SE
Device #1: ID 0x2c MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. MacBook Pro Speakers
