Hello
I am using Audirvana with a Macbook Pro and a Naim Unitilite. Often but not always a track will skip after a few seconds and go to another. What am I doing wrong?
Thank you.
Terence
Hello
Thank you.
Terence
Hello @TerenceJ,
macOS 10.15.7 with 8192MB RAM
Per track: OFF
Max allowed volume: 87.0871
SW volume control: ON
AUTO: /Users/terenceollerhead/Music/Music
iTunes/Music library synchronization: last synchronized on Mon Mar 15 14:09:51 2021
Library database path: /Users/terenceollerhead/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: Lite-27F1 Model UID:Naim Audio Ltd. Lite-27F1 UID:uuid:5F9EC1B3-ED59-79BB-4530-0011F6AB27F1
Currently playing to UPnP device at 24 bits 192kHz
UPnP device at http://192.168.0.27:8080/description.xml
ID 0x0 Lite-27F1 Manufacturer:Naim Audio Ltd.
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/L16;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/wav:*
http-get::audio/x-mpegurl:
http-get::application/ogg:
http-get::audio/mp4:
http-get::audio/x-flac:
http-wavetunes::audio/x-ms-wma:
http-get::audio/x-aiff:
http-get::audio/x-m4a:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::application/x-mpegurl:
http-get::audio/x_pm_flac:
DLNA 1.5: No
Gapless playback: Yes
Can play native DSD: Yes
14 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:04:45
CurrentURI: http://192.168.0.29:49152/audirvana/audio_0_0.wav
CurrentURIMetadata: dc:titleRameau, Ólafsson: The Arts and the Hours</dc:title>upnp:artistÓlafsson Víkingur</upnp:artist>upnp:albumCollection: Ólafsson: Debussy, Rameau</upnp:album>upnp:albumArtURIhttp://192.168.0.29:49152/audirvana/artwork_0_1.jpg</upnp:albumArtURI>http://192.168.0.29:49152/audirvana/audio_0_0.wav
nextURI: http://192.168.0.29:49152/audirvana/audio_1_1.wav
nextURIMetadata: dc:title8. La fille aux cheveux de lin</dc:title>upnp:artistÓlafsson Víkingur</upnp:artist>upnp:albumCollection: Ólafsson: Debussy, Rameau</upnp:album>upnp:albumArtURIhttp://192.168.0.29:49152/audirvana/artwork_1_2.jpg</upnp:albumArtURI>http://192.168.0.29:49152/audirvana/audio_1_1.wav
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportState string STOPPED PLAYING PAUSED_PLAYBACK TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NETWORK RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Lite-27F1 Naim Audio Ltd. http://www.naimaudio.com Naim UnitiLite all-in-one audio player UnitiLite 20-002-0015 https://www.naimaudio.com/product/unitilite 0011F6AB27F1 uuid:5F9EC1B3-ED59-79BB-4530-0011F6AB27F1 123810928305556upc urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-dm-holdings-com:service:X_HtmlPageHandler:1 urn:schemas-dm-holdings-com:serviceId:X_HtmlPage /HtmlPageHandler/desc.xml /HtmlPageHandler/ctrl /HtmlPageHandler/evt http://192.168.0.27:80/index.asp urn:rhapsody-real-com:device-id-1-0:rdk_dev_2:0011F6AB27F1UPnP devices found : 1
Device #0: ID 0x0 Lite-27F1 UID: uuid:5F9EC1B3-ED59-79BB-4530-0011F6AB27F1 Location: http://192.168.0.27:8080/description.xml
Max. memory for audio buffers: 3268MB
Exclusive access: Disabled
Device #0: ID 0x32 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:82 UID: AppleHDAEngineOutput:1B,0,1,1:0
Can you try to disable software volume control and enable exclusive access and try again?
Hello Damien. Thank you for responding. SW volume control is on, but won’t go off. And where is exclusive access on a Mac? Thank you.
You need to stop the audio using the square icon. Yes there is Exclusive access on Mac, you need to go in audirvana output settings.
Bonjour Damien. I am doing better. I’ve done as you say, and the playing is stable. I have FOR NOW just one more question. The square speaker box symbol. When I click it, it shows two sections: one is DAC, with built-in output, and the second piece has NETWORK, and the name of my Naim system. What should I be using? I’ve been usind the network, but should I use DAC? Merci beaucoup. Terence
The DAC section is the outputs that are connected to your computer (either via USB or your local sound card). The NETWORK is for the UPnP outputs you have that can be played with Audirvana. The main difference between them is the capacity of the output as one can for example could play at a higher frequency than the other. Those differences are indicated in your device manual.
For your Naim you see it in the Network section which means you play to it over UPnP. Note that Audirvana sent the audio in .wav in UPnP so the track is not alliterated when it arrive to your Naim.
Thank you so much, Damien, for taking this time. I am not completely clueless, but the DAC world is full of acronyms and new words! Audirvana this weekend worked flawlessly. Must have been the tweaks that you suggested last week. One last question; is the fidelity the same using the Legacy feature? Not that I’m really tempted, as Audirvana is so good. I’ll be buying! Thank you.
The Legacy feature allows you to use Music but with the sound of Audirvana so yes, the fidelity is the same.
