Just starting, why is the sound playing in slow motion? I’m on a MacBook Air M1 and trying to stream from Tidal Master. I’m connected by hdmi to Yamaha RX A2080 and Sony Bravía A80j.
Hello @Yobder,
Are you abel to reproduce this issue easily?
Audirvana Studio 1.10.2 (11002)
macOS Version 12.1 (Build 21C52) with 8GB physical RAM
Connected account of : Mack Johnson
Sync list: 0 folders
Library database path: /Users/mackjohnson/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 52990
SNY SONY TV *30
Model UID:4DD905B9-0000-0000-011F-010380AA6078
Device: 6ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 24 bytes per frame 48kHz
Active Sample Rate: 48kHz
Hog Mode is on
ID 0x42 SONY TV *30
Manufacturer: SNY
Model Name: SNY SONY TV *30
Model UID: 4DD905B9-0000-0000-011F-010380AA6078
6 available sample rates up to 768000Hz
32000
Audio buffer frame size : 15 to 2304 frames
Multichannel: 6 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 3
Channel 3 mapped to 2
Channel 4 mapped to 4
Channel 5 mapped to 5
Number of channels: 6
Simple stereo device: No
Number of active channels: 6, in 1 stream(s)
Stream ID 0x43 6 channels starting at 1
5 virtual formats:
3 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
5 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
6 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
15 physical formats
3 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
5 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
6 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
3 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
4 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
5 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
6 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
3 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
4 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
5 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
6 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
Local devices found : 4
Device #0: ID 0x42 SONY TV *30 Manufacturer: SNY Model UID: 4DD905B9-0000-0000-011F-010380AA6078 UID: 4DD905B9-0000-0000-011F-010380AA6078 Model Name: SNY SONY TV *30
Device #1: ID 0x36 MacBook Air Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. MacBook Air Speakers
Device #2: ID 0x32 Jump Desktop Microphone Manufacturer: Phase Five Systems LLC Model UID: com.p5sys.jump.audio.driver.mic UID: com.p5sys.jump.audio.driver_mic_v001 Model Name: Phase Five Systems LLC Jump Desktop Microphone
Device #3: ID 0x2e Jump Desktop Audio Manufacturer: Phase Five Systems LLC Model UID: com.p5sys.jump.audio.driver UID: com.p5sys.jump.audio.driver_v001 Model Name: Phase Five Systems LLC Jump Desktop Audio
UPnP devices found : 1
Device #0: ID 0x0 Pace RVU Client MediaRenderer UID: uuid:MediaRenderer-54_E2_E0_BD_9B_AF Location: http://169.254.7.38:63445/upnp/xml/devices/MediaRenderer1.xml
Hi, it’s playing at normal speed now I just clicked on stuf. haha! it only works going through my TV HDMI and not my receiver’s HDMI so don’t know if I’m getting the highest quality sound from Tidal. I have a little time to figure this out, if I can’t I’ll have to pass on this software and try another.
Effects plugins ACTIVE in offline mode with legacy macOS API
No plugin active
iTunes/Music library synchronization: last synchronized on Sat Jan 29 13:40:12 2022
Listening on 127.0.0.1 on port 49589
CoreAudio audio path, buffer I/O frame size: 4096
SNY SONY TV *30
Model UID:4DD905B2-0000-0000-011F-010380AA6078
Device: 8ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 32 bytes per frame 48kHz
Hog Mode is on
ID 0x2e SONY TV *30
Manufacturer: SNY
Model UID: 4DD905B2-0000-0000-011F-010380AA6078
7 available sample rates up to 768000Hz
32000
Multichannel: 8 channels
Channel 6 unused
Channel 7 unused
Number of channels: 8
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
Stream ID 0x2f 8 channels starting at 1
7 virtual formats:
7 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
7 physical formats
7 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
Device #0: ID 0x2e SONY TV *30 Manufacturer: SNY Model UID: 4DD905B2-0000-0000-011F-010380AA6078 UID: 4DD905B2-0000-0000-011F-010380AA6078 Model Name: SNY SONY TV *30
Device #1: ID 0x45 MacBook Air Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. MacBook Air Speakers
Device #2: ID 0x41 Jump Desktop Microphone Manufacturer: Phase Five Systems LLC Model UID: com.p5sys.jump.audio.driver.mic UID: com.p5sys.jump.audio.driver_mic_v001 Model Name: Phase Five Systems LLC Jump Desktop Microphone
Device #3: ID 0x3d Jump Desktop Audio Manufacturer: Phase Five Systems LLC Model UID: com.p5sys.jump.audio.driver UID: com.p5sys.jump.audio.driver_v001 Model Name: Phase Five Systems LLC Jump Desktop Audio
I don’t see your Yamaha in the list of the outputs. Can you make sure you selected it before pressing the debug info button?
