hi Damien
copied and pasted below…
Audirvana Mac Version 3.5.30 (3560)
macOS 10.15.3 with 32768MB RAM
Registered to David Doran
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
AUTO: /Volumes/Cart 2.3/music.MBP 2.2/# Beatport aiff download
Library database path: /Users/davidwd2/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Display Audio
Model UID:Display Audio:05AC:1107
UID:AppleUSBAudioEngine:Apple Inc.:Display Audio:172105EE:2,1
Active Sample Rate: 48kHz
ID 0x59 Display Audio Manufacturer:Apple Inc.
Model UID:Display Audio:05AC:1107 UID:AppleUSBAudioEngine:Apple Inc.:Display Audio:172105EE:2,1
2 available sample rates up to 48000Hz
Stream ID 0x5a 2 channels starting at 1
6 virtual formats:
8 physical formats
Device #0: ID 0x59 Display Audio Manufacturer: Apple Inc. Model UID: Display Audio:05AC:1107 UID: AppleUSBAudioEngine:Apple Inc.:Display Audio:172105EE:2,1
Device #1: ID 0x4d MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
have no idea obviously what this means - but hopefully will clarify something .
oh - and files are located on a second disk partition
