I want to make a smart playlist with ‘Hits’ ‘Best Of’ and ‘Greatest’
That works fine, but after making I want to exclude one of the albums with ‘Christmas’. I can delete the songs but I don’t see them back in my general library. I mean outside the playlist I generated. They seem to be place in the Recycle bin.
Thanks! I know how to restore them, but then they will come back in the generated smart playlist ‘Hits’ too. I did take a look at simple playlist, but can’t see a solution there. It’s all about excluding a part of the generated album selection, in this case albums with the word ‘Christmas’ in it.
redo what you did… then, remove the christmas from the smart playlist…
now they are in the trash…
create a simple playlist name whatever…
go to the smart playlist and select all in it,
drag the files in the new simple playlist…
now you have all except christmas…
then restore your files in the trash
and trash the smart playlist…
just keep the simple one with all the songs in it you want.
