I can’t seem to be able to create smart playlists in Audirvana Studio. When I click on the funnel icon, the icon with the plus sign to “Add rule” is grayed out. The Add Filter function works, but not smart playlists. I am using an M1 Mac mini.
And you have selected the playlist in the manager like I’ve done in the screenshot?
OK, I think I got it to work. I did not select playlist from the manager first.
Thanks!
