- after I search for a song in Qobuz or Tidal, it will not play. If I go to the Qobuz or Tidal page in Studio, those songs will play. This does not happen in 3.5.
- we need the remote app out ASAP. The Studio trial should not have even started until the remote was out and working.
Did you even try to have a group of actual beta testers? If we are testers, turn off the trial period until some of these bugs are fixed. I like the sound of 3.5 and Studio when it works better than Roon, but it really needs fixed. Also, please make the remote look better than the old remote…
