Hello. I just installed the trial version for Windows 10.I activated ASSIO drivers and i try to play MQA music via TIDAL with my CA DAC Magic Plus,conected direct to final amplifier.Music play at maximun level,software volume control not work.What is the problem?
Can you dump the debug info here?
What kind of debug information?Print screen etc?
Nope, go in the first menu and click on “Debug Info…”. This will put the debug info in the clipboard, then just paste it here.
everything is ok!volume control works!thank you very much!
