Damien, as requested…
Audirvana Mac Version 3.5.33 (3563)
macOS 10.15.3 with 8192MB RAM
Sync list: 2 folders
AUTO: /Users/davidcollins/Library/Containers/nz.co.pixeleyes.AutoMounter/Data/Mounts/Diskstation2/SMB/hiresmusic/
AUTO: /Users/davidcollins/Library/Containers/nz.co.pixeleyes.AutoMounter/Data/Mounts/Diskstation2/SMB/music/Music
Library database path: /Users/davidcollins/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
LS50 Wireless Speaker
Model UID:LS50 Wireless Speaker:27AC:1050
UID:AppleUSBAudioEngine:GP Acoustics (UK) Ltd:LS50 Wireless Speaker:14200000:1
Active Sample Rate: 48kHz
ID 0xdd2 LS50 Wireless Speaker Manufacturer:GP Acoustics (UK) Ltd
Model UID:LS50 Wireless Speaker:27AC:1050 UID:AppleUSBAudioEngine:GP Acoustics (UK) Ltd:LS50 Wireless Speaker:14200000:1
Stream ID 0xdd3 2 channels starting at 1
18 virtual formats:
24 physical formats
Local devices found : 3
Device #0: ID 0x33 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0xddb HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{D94D-7C04-01010101}
Device #2: ID 0xdd2 LS50 Wireless Speaker Manufacturer: GP Acoustics (UK) Ltd Model UID: LS50 Wireless Speaker:27AC:1050 UID: AppleUSBAudioEngine:GP Acoustics (UK) Ltd:LS50 Wireless Speaker:14200000:1
UPnP devices found : 1
Device #0: ID 0x0 LS50 Wireless - Lounge UID: uuid:5f9ec1b3-ed59-1900-4530-84171500dad6 Location: http://192.168.0.180:8080/description.xml
