SOLVED - AS 1.8: crash when paying DSD 64 files
Dear all,
With the freshly installed AS 1.8 I tried to play some DSD 64 files I used to play with the previous version.
I systematically get an arithmetic exception and a complete crash: division by zero.
Here is the message:
Exception Type: EXC_ARITHMETIC (SIGFPE)
Exception Codes: EXC_I386_DIV (divide by zero)
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Floating point exception: 8
Termination Reason: Namespace SIGNAL, Code 0x8
Terminating Process: exc handler [33676]
Eric
This is fixed in 1.8.1.
You can get it by using the “Check for updates…” command of the Audirvana Studio menu.
Thanks Damien.
It’s working now.
