OK. Good luck !
Unfortunately I don’t see any possibility to go on with AS. There is a showstopper upnp problem with AS and my Marantz AVR.
I’ve switched from Tidal to Qobuz. So I don’t need MQA unfolding. I installed BubbleUpNp Server on Mac Mini and Linn controller on my iPhone. It works perfectly so I’m leaving Audirvana software.
But Audirvana sounds better !!! Why??? Both are bit perfect, or not?
Seems that in the last versions of AS this problem was solved!!! So for now that problem can be closed.
The problem is back. I don’t why it worked Ok for a few days and why the problem is back now.
The main question is @Damien is there someone who can debug it with me? Where to report this problem in order that someone can communicate with me. Thank you
Did you try to hard restart the receiver?
I find the reason. The problem is related to the RAW PCM setting. When I disable it, it works perfectly. Does it make a difference in the sound quality? Waw vs. RAW PCM?
It shouldn’t. It’s not that you have choice, one works and the other doesn’t.
