I have similar issue. I am setting up a new Macmini media server and installed fresh Audirvana and must have licensed on the Mini but then decided to clone OS from previous machine after some other unrelated issues. I now can’t license on the Mini. Can you plase reset my computers also?
Audirvana is linked to your operating system so if you change your PC components like your CPU you don’t have to reactivate Audirvana. Be careful if you change the hard drive where your operating system is running, you will have to reactivate Audirvana.
thx for your replay.
In this days I’ll will take a new back up from my main hard-drive with the Operating System and all Programms I use.
It will be a complete mirror
I will not really use this copy, but in the cause of a systeme damage it will be more simple to exchange the harddrive than replace all programms with their individually settings, wich i optimized in the last weeks.
In the case of the limited activation I think there is a gernerall problem, in cause of the “life-time-licence”.
If there sometimes audirvana will not further supported, there will no possibility to use audirvana in further times.
I understand your problem about not licenced copys, but for us as customer it is not the best way like it is at the moment.
You are friendly and helpful, and set the licences back, but more simple it would be, if this was not neccessary.
Anyway, thx for your help!
I have the same problem- “too many…” on a mac. As far as I know I have only one other installation. Please reset my license so that I can install on 2 mac computers. Thank you.
