Thanks Damien - here’s the Debug info :
macOS 10.13.6 with 8192MB RAM
Registered to Francis Ermes
Replay Gain: by album
SW volume control: ON
AUTO: /Volumes/Music/
iTunes/Music library synchronization: last synchronized on Sun Mar 14 12:31:06 2021
Library database path: /Users/frankermes/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
CoreAudio audio path, buffer I/O frame size: 4096
Built-in Output
Model UID:AppleHDA:29
UID:AppleHDAEngineOutput:1B,0,1,2:0
Device: 2ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 8 bytes per frame 88.2kHz
Active Sample Rate: 88.2kHz
Hog Mode is on
ID 0xc1 Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:29 UID:AppleHDAEngineOutput:1B,0,1,2:0
5 available sample rates up to 96000Hz
32000
Audio buffer frame size : 27 to 4096 frames
Stream ID 0xc2 2 channels starting at 1
5 virtual formats:
20 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 32kHz
Local devices found : 3
Device #0: ID 0xc1 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:29 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x28 Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Device #2: ID 0x33 Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1
As for the sorting…as I was typing this reply out, I noticed that Audirvana is showing “compilation” albums first - that is, albums containing songs by various artists. Scrolling down further, I can see albums listed in alphabetical order by artist…doh!
My apologies - I guess I’m so used to looking at an iTunes display I didn’t see what was staring me right in the face with a different display.
Frank.
