Some problems with library
I found two problem with my music library.
Firstly, the Audirvana can not get all files from hard drive. After symbol «M», Marbin, sychronization stopping every times.
The Audirvana doesn’t see most of my library.
Next problem is album artefacts. Instead of one album, the Audirvana shows an whole album and several tracks as a second album. I do not have duplicates of files on my hard drive. The metadata in the folder is the same, but Audirvana interprets one folder as two albums. I may need to delete the Audirvana’s library file, but I do not know where it was created.
Please help to make my Audirvana better.
Hi @LuckyRo,
Thanks for your attention. I found and deleted library file. After it I rebuilt library and choose each folders.
Audirvana Origin 2.5.21 (20522)
macOS 15.3.1 ARM64 with 16GB physical RAM
Connected account of : Kirill Kuzmichev
Local network access: allowed
SW volume control: ON
Sync list: 5 folders
AUTO: /Volumes/SG4Aux_HDMusic/[HD] Library/Classic
AUTO: /Volumes/SG4Aux_HDMusic/[HD] Library/Jazz Jam
AUTO: /Volumes/SG4Aux_HDMusic/[HD] Library/New Wave
AUTO: /Volumes/SG4Aux_HDMusic/[HD] Library/Rock
AUTO: /Volumes/SG4Aux_HDMusic/Vinyl rip
Sort and display order: en
Library database path: /Users/kuzmichev/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on on port 64282
Font size: large
Language: English
My Music
Library
Use Apple Remote: yes
Number of paired remotes: 3
Screen saver disabled: no
Max. memory for audio buffers: 7398MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
SMSL USB AUDIO
Model UID:SMSL USB AUDIO:152A:85DD
UID:AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:1100000:1
Selected device:SMSL USB AUDIO
Manufacturer: SMSL
Model name: SMSL USB AUDIO
Model UID: SMSL USB AUDIO:152A:85DD
UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:1100000:1
USB Vendor ID: 0x152a
USB Product ID: 0x85dd
ID 0x4e
MQA Decoder device
Unhandled (PCM conversion) with boost gain of 3dB
Stream ID 0x4f 2 channels starting at 1
30 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 768kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 705.6kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 384kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
40 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 768kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 705.6kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 352.8kHz
Local devices found : 3
Device #0: ID 0x52 S95D
Manufacturer: SAM
Model UID: 4C2D2675-0000-0000-0122-010380794478
Model name: SAM S95D
Device #1: ID 0x4e SMSL USB AUDIO
Manufacturer: SMSL
Device #2: ID 0x48 Динамики Mac mini
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Динамики Mac mini
Selected Network interface: Ethernet
Ethernet
Does the tracks you don’t see are located only in one of those folders?
Yes. At this folder: AUTO: /Volumes/SG4Aux_HDMusic/[HD] Library/New Wave
If I choose for synchronisation upper folder
Audirvana breaks synchronisation
If I choose for synchronisation each folder
Audirvana starts a synchronisation. I try to get full synchronisation
Can you go into the Audirvāna settings and in the My Account section? You will see a ‘Start Log Session’ button; click on it and reproduce your issue. After you reproduce it, click 'Stop Log Session’ and send me the audirvana_origin.log file you can find by clicking the 'Open Log Folder’ button at [email protected]
You mean I need to recompilate my library again?
Today I spent all day to try a variants for build library. My last last effort gives a result:
all files got into library. But I can to repeat compilation for you!
Thanks to works with library Audirvana automatically resolve my first problem - artefacts with albums:
My last question is how to get access to “delete” function?
If you don’t have the issue anymore, then it’s not needed.
The delete function is only available in the Track view of Audirvāna.
I will try to recompile again at weekend. With log session.
Dear Antoine, help me please with Queue function. On my Audirvana ver 2.0 I can drop to queue any files what I need. I can’t access this function right now. If I need to listen a file, I must to add it to the library first. Is this the right way now?
You can do this using this link:
