Le voici :
macOS 10.13.6 with 8192MB RAM
SW volume control: ON
Manual: /Users/frederik/Music/ELECTRO 90
Library database path: /Users/frederik/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
MICROMEGA MYDAC USB 2.0 Audio Out
Model UID:MICROMEGA MYDAC:26F2:0200
UID:AppleUSBAudioEngine:MICROMEGA :MICROMEGA MYDAC:0000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
ID 0x28 MICROMEGA MYDAC USB 2.0 Audio Out Manufacturer:MICROMEGA
Model UID:MICROMEGA MYDAC:26F2:0200 UID:AppleUSBAudioEngine:MICROMEGA :MICROMEGA MYDAC:0000:1
Stream ID 0x29 2 channels starting at 1
12 virtual formats:
12 physical formats
Device #0: ID 0x38 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:29 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x28 MICROMEGA MYDAC USB 2.0 Audio Out Manufacturer: MICROMEGA Model UID: MICROMEGA MYDAC:26F2:0200 UID: AppleUSBAudioEngine:MICROMEGA :MICROMEGA MYDAC:0000:1
UPnP devices found : 1
Device #0: ID 0x0 décodeur TV 4 UID: uuid:00ababad-7947-1048-8a00-247f20f39669 Location: http://192.168.1.18:42300/description.xml
