At first I thought i was my fav list but not so. Dosnāt affect local playback. Problem is inconsistent as to how long song will play before stopping and moving to next. Canāt think what did different, Was working fine. Did upgrade Dirac⦠Thanks!
Hi @tccaux,
Can you send us a copy of the āDebug Infoā when you have this issue? You can get it in Audirvana Settings>My account
Hereās debug, However, the problem has gone away and I canāt tell you what changed, BTW, Iām using Quboz.
Audirvana Studio 2.2.3 (20203)
macOS 10.15.7 with 8GB physical RAM
Connected account of : Terry Clotiaux
AU plugin #0: Effect - Dirac Research DiracLiveProcessor ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
SoX custom frequencies
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: /Volumes/Music Server 1/Music Server 16_v2
iTunes/Music library synchronization: last synchronized on Tue Jun 8 16:20:20 2021
Library database path: /Users/MR_MUSIC/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 55947
Max. memory for audio buffers: 5998MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
PS AUDIO PS AUDIOUSB 2.0 AUDIO OUT
Model UID:PS AudioUSB Audio 2.0:2616:0102
UID:AppleUSBAudioEngine:PS Audio:PS AudioUSB Audio 2.0:0000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
Selected device:PS AudioUSB 2.0 Audio Out
Manufacturer: PS Audio
Model name: PS AudioUSB 2.0 Audio Out
Model UID: PS AudioUSB Audio 2.0:2616:0102
UID: AppleUSBAudioEngine:PS Audio:PS AudioUSB Audio 2.0:0000:1
USB Vendor ID: 0x2616
USB Product ID: 0x0102
ID 0x2b
Stream ID 0x2c 2 channels starting at 1
12 virtual formats:
12 physical formats
Local devices found : 3
Device #0: ID 0x40 Built-in Output
Model UID: AppleHDA:82
Device #1: ID 0x2b PS AudioUSB 2.0 Audio Out
Device #2: ID 0x34 Dirac Virtual Audio Device
Manufacturer: Dirac Research AB
Model UID: com.dirac.vad_ModelUID
UID: com.dirac.vad_UID
Model name: Dirac Research AB Dirac Virtual Audio Device
Next time it happens, please tell me whether it was something from Qobuz or from your local library to narrow the issue
Itās mostly from Quboz. Should have mentioned that. I think itās the Dirac pluginā¦
When I turn off the Dirac, thereās no problem. Now trying to figure out how to reconfigure Dirac.
Now on M2 Mac mini so Iāve added a lot of new variables.
Thanks so much!
maybe there is an update for Dirac for new M2 Mac or not yet like it is often the caseā¦
MĆŖme chose avec Tidal
