If i use the smart:EQ 3 vst3- Plugin with Audirvana (both versions) on Mac OS Monterey, it crash immediately.
On Windows it works perfect.
If there any solution?
My experience with AU plug-ins that are not working as expected, is to first check with the developer of the plug-in application and verify compatibility with the macOS I’m running…
You need to use Audio Unit if you are using the MacOs version of Audirvāna, not the VST3.
Hi,
thank you for your answer. What do you exaclty mean? Whitch AudioUnit? I install the plugin normaly…
When you install the plugin, you should had a choice between different type of plugins (VST, VST3, AU, AAX). You need to install the AU version.
Thank you for your support.
I’ve deleted all vst Plugins and installed only the AU- Version.
It crash…
gladly…
I’ve try it on another MacBook Pro. It’s the same…
Hello @Bujo12,
Have you sent us the crash report? If you can’t find it, it’s in the Console app of MacOS.
