Sonictransporter i7 Audrivana, USB DAC not recognized as option, fine on Roon,Plays fine Network
I have an Aperio system, sonictransporteri7, phoenix network switch,Phoenix USB re-clocker. Audrivana provides playback via my Aperio (Dac) on the network input fine. Does not show USB selection in audrivana only UPnP no mater what input I select on my DAC. Roon works fine both ways? what’s up can’t play USB on Audrivana?
Sounds like you need to shut-down Audirvāna and your re-clocker and DAC. restart the SonicTransporter i7, making sure you have the proper ‘Bridge’ settings, restart your re-clocker and then restart your DAC… If the behavior persists, then connect your DAC directly to the SonicTransporter to get a baseline operational reference to troubleshoot from…
If the condition continues to persist, then it is time to contact Small Green Computer support and Warwick Acoustics support for assistance.
This article may be relevant:
Did you try to connect the DAC directly to the USB out of the Sonictransporter, to see if the Phoenix USB reclocker is the problem?
Issue resolved, not really sure how. logged in and it was there? go figure
