I use Sonimus SonEQ with Audirvana.
Now I bought Sonimus SonEQ Pro
I cannot find this Plugin in Audirvana “Signal Processing - VST3 plug-ins”. There is only Sonimus SonEQ.
Does the Pro -Version not work in Audirvana?
Hello @wiwal, which version of the plugin did you installed? If its the VST3 version you installed then you won’t be able to see it in Audirvana since the Mac version can only use the Audio Unit version of the plugin.
Thank you for the quick answer.
I reinstalled the plugin and restarted the Mac. Now everything works great! I now use Sonimus SonEQ Pro with Audirvana.
