Hello folks,
thanks for your support.
Is there any chance to use my Sonos system as output device?
thanks
Andrea
Hello folks,
thanks
Andrea
Hi @Andrea_Riela,
You should be able to play to it via Bluetooth/Airplay. In such a case, you need to select the device as an output in your computer before being able to select it in AudirvÄna.
Hi Antoine,
thanks for sharing. Any option to do it with AudirvÄna installed on my NAS (qnap)? or is it something I can manage on remote?
As alternative, if this can be easier, I can create a linux VM and install AudirvÄna in it ⦠but same question, if itās possible to find a way to use Airplay to connect my Sonos devices and stream 24/48 music.
thanks again
Andrea
