Inkadue
1
Hello,
my idea is to list various recordings of Beethoven´s Symphonies in the order of the symphony number.
So I titled the albums as follows
- LvB: 1. Symphonie, Nikolaus Harnoncourt
- LvB: 1. Symphonie, H.v. Karajan
- LvB: 1. Symphonie, Herrmann Scherchen
etc.
for all recording I filled in the field SORTED BY with 1. Symphonie
Alas, the result is not what I expected. Audirvana sorts the symphonies by artist and even places other works in between the symphonies (see below).
How comes? What can I do?
Antoine
2
Hello @Inkadue,
What are your sorting criteria in Audirvana settings?
Inkadue
4
Hi @Antoine ,
I just changed the criteria:
More logical, but still odd:
What is this attribute for?
Antoine
5
sortiert nach tag is the tag we use to sort your albums, can you check the others how are not properly sorted?
Inkadue
6
They are properly set to LvB: 1. Symphonie. I did for that purpose.
Inkadue
7
I found a stupid workaround: I selected for the first sort critera: file location.
And since all my folders are properly named I got what I wanted:
But it is still a miracle to me.
Antoine
8
All of the LvB: 1. Symphonie album have this sorting criteria? What about the other LvB albums you have?
Inkadue
9
All three 1st Symphonies have criteria: LvB: 1. Symphonie
All three 3rd Symphonies have criteria: LvB: 3. Symphonie
my expectation would be to have each grouped accordingly.
Inkadue
10
@Antoine Stupid me! Look at one of my first screen shots.
Instead of criteria for ALBUM I defined criteria for TITLE. No it works fine, even without the explicitly defined search criteria:
Merci pour votre service!
Ingo
system
Closed
11
