Not sure what’s causing this but, in the silence between tracks, I seem to be getting a split second of noise from an unrelated piece of music, at a louder volume level than the preceding and successive tracks. I am runnning a new install win 10 & AS on a Lenovo tiny pc (I think it’s an M83 with Intel I5, 240Gb SSD, 8 Gb ram, with local files fed from a 1 Tb USB SSD.
I had this problem with the trial version of AS when it first came out. Then, it ran directly into a Rega DAC-R via USB from the pc. I appear to be hitting the same problem with a Topping D10S which is doing conversion from USB to S/PDIF before being sent on to the same Rega DAC. I was hoping that it might be some early version glitch that would have been ironed out in later ones, but the issue still persists. Until recently, I have been using Volumio which sounds great but the user interface is clunky and unreliable. Hence why I came back to Audirvana.
HI @walriley,
only using this up to 24/192 as the Rega doesnt do DSD.
Audirvana Studio 2.4.0 (20400)
Windows 10 (19045) with 8GB physical RAM
Connected account of : walter riley
r8brain with Power Of Two upsampling
AUTO: F:
Library database path: C:\Users\PC\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 398
Listening on 192.168.0.198 on port 49673
Max. memory for audio buffers: 4096MB
Speakers (TOPPING USB DAC)
Model UID:TUSBAUDIO_ENUM\VID_152A&PID_8750&REV_0104&KS
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{efaa6ead-b5ca-472e-9255-3a7407650d83}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 24bits Integer, 8 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Selected device:Speakers (TOPPING USB DAC)
Manufacturer: Topping
Model name: D10s
Model UID: TUSBAUDIO_ENUM\VID_152A&PID_8750&REV_0104&KS
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{efaa6ead-b5ca-472e-9255-3a7407650d83}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x152a
USB Product ID: 0x8750
Kernel Streaming capable
Max volume alert: Disabled
Simple stereo device: No
Device #0: Speakers (TOPPING USB DAC)
Model name: D10s
Device #1: R50B7120UK (Intel(R) Display Audio)
Manufacturer: Intel(R) Corporation
Model UID: HDAUDIO\FUNC_01&VEN_8086&DEV_2807&SUBSYS_80860101&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b7cced7c-e6b9-4cd3-bc30-0c2392357d8d}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Can you try without upsampling enabled?
Tried without upsampling. There is still a slight jump between tracks that should be gapless. Seems to be on both CD and HD tracks.
I would like to add that the upsampling really does seem to lift the music, hence why I have it switched in.
Ok then do you have the same behavior using WASAPI or ASIO?
Seems to be behaving itself on the two options you requested. Plays fine on WASAPI and ASIO. No stutter or noise burst between gapless tracks.
But I have Audirvana 3.5 to play in those formats.
Are there any settings in either AS or Win 10, that will allow me to utilise the Kernel Streaming option?
Can you go in your device settings in Audirvāna Studio and change the Kernel Streaming level from Standard to Extreme or the contrary depending on your setting? You still have your issue after doing this?
I will give it a go as soon as I can. Also, looking into whether the USB connection for the music library is causing a problem and if the ASIO driver for the Topping DAC is causing interference.
Had a limited test, with no drivers for the Topping DAC installed, and with all the music on the main computer drive. Kernel mode was on and set to extreme. It initially appears that the issue is sorted, but don’t have enough time to figure out which change cured it. Will soak test it tonight and report back once I’ve narrowed it down.
It seems that if I am running Audirvana in Kernel Mode, then any WASAPI or ASIO drivers installed for their respective DACs will conflict with that mode. I have tried Audirvana with both internal and USB music folders and both work fine as long as the DAC drivers are not installed. Audirvana worked flawlessly for hours last night. It did fall over at one point and generated a .dmp file. If that is of any use to the forum moderators then let me know and I will forward it on.
Apologies for the delay. I will forward all the mini dump files now.
