Hi, I got problem with dsd and pcm larger 24/96khz. Some song get distortion when playing. Especial dsd file, the problem happen much. If I play file 16/44khz then everything is fine. What should I do now? Thank you!
Debug info:
Audirvana 3.5.43
Replay Gain: by album
SW volume control: ON
AUTO: D:\Music
Library database path: C:\Users\HPS01\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 12798MB
Local Audio Engine:ASIO 2 driver version 2
ASIO Chord 1.05
Model UID:ASIO Chord 1.05
UID:ASIO Chord 1.05
Device: 2ch 32bits Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Sample rate switching latency: 1s
ASIO Chord 1.05 Manufacturer:
Model UID:ASIO Chord 1.05 UID:ASIO Chord 1.05
12 available sample rates up to 1536000Hz
1411200
1536000
2 ch Integer PCM 32bit little endian 1411.2kHz
2 ch Integer PCM 32bit little endian 1536kHz
Device #0: ASIO Chord 1.05 Manufacturer: Model UID: ASIO Chord 1.05 UID: ASIO Chord 1.05
UPnP devices found : 1
Device #0KD-55X7500F UID: uuid:23456789-1234-1010-8000-702605BCF706 Location: http://192.168.1.4:52323/MediaRenderer.xml
