Hi, I recently purchased an AUDIO-GD DI24HE. I need a DDC because the DAC in my Lyngdorf amp only has SPDIF inputs, no USB.
Iām using the factory ASIO driver for the built-in Amanero USB interface.
Everything plays fine, Iām very happy with the sound, until I de-activate the exclusive audio access (padlock icon). When starting to play again and thus re-activating the exclusive access, the sound is distorted. The sound remains distorted even when switching to another player (e.g. VLC)
There is no way to get rid of the distortion: stop and re-launch audirvana; restart PC; restart DDC⦠nothing helps.
Except, I found out by coincidence, after fiddling with the audio interface in another program (in this case JRiver). That brings back the clean sound, also in Audirvana.
Am I wrong in thinking that Audirvana confuses the USB interface with its exclusive access switch? If so, is there a solution?
If relevant, please see my debug info below.
Cheers,
Peter
Audirvana Studio 2.7.0 (20700)
Windows 11 (22631) with 16GB physical RAM
Connected account of : ano nominus
Available network interfaces:
Ethernet ({33a8495b-f4a9-432f-a1c6-6353b86ed1fa}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Third party firewall installed and registered in place of Windows Defender:
Bitdefender Firewall
Replay Gain: by track
Sync list: 1284 folders
[ā¦Sync list removed to shorten message textā¦]
Tracks with no MBID: 15284
Listening on 2a02:1810:280c:4800:f98b:1f0f:b405:2430 on port 56343
Max. memory for audio buffers: 8192MB
Local Audio Engine: ASIO 2
Driver version 1
Amanero ASIO Combo384
Model UID:Amanero ASIO Combo384
Device: 2ch 32bits Integer, 8 bytes per frame 44.1kHz
Selected device:Amanero ASIO Combo384
Manufacturer:
Model name: Amanero ASIO Combo384
Model UID: Amanero ASIO Combo384
2822400
5644800
11289600
22579200
Raw DSD (msb)
Device #0: Amanero ASIO Combo384
Manufacturer:
Device #1: JRiver Media Center 31
Manufacturer:
Model UID: JRiver Media Center 31
Model name: JRiver Media Center 31
UPnP devices found : 4
Device #0: iFi
UID: uuid:48e75bf1-ed45-6dbf-cc31-cabdae7e02d4
Manufacturer: iFi audio
Model name: iFi audio
Device #1: CompMuziek
UID: uuid:082576f0-008b-4f90-963f-02a10c909e0f
Location: http://192.168.0.156:52101/DeviceDescription.xml
Manufacturer: JRiver, Inc.
Model name: Media Center
Device #2: CompMuziek: VLAV
UID: uuid:51aa52f7-3dbb-4546-9b95-df08ae3ae747
Location: http://192.168.0.156:52102/DeviceDescription.xml
Device #3: CompMuziek: WebPlayer
UID: uuid:3c7d454c-5453-4e28-b16d-b566118f391b
Location: http://192.168.0.156:52103/DeviceDescription.xml
