Hi,
now that the remote app is available I did an intensive test of Audirvana Studio.
I have directly compared the sound quality between Audirvana Studio and Audirvana. The latter one wins about Studio, because the mid range is much more present and fits better to my setup (B&W CM8S2 and Rote RSP-1576). Audirvana Studio lacks a lot of room information which sounds pretty poor. Maybe this is related to my individual setup (preamp/speakers/room), but the result is that I’ll stay with Audirvana as long as it will be supported or until Studio will give better sound. If Audirvana stops being supported for macOS anymore it’s maybe time then for a dedicated player.
Cheers,
Stefan
