Hello,
The Sound without tidal is very good. The Sound with tidal is Bad.
Please help me
… maybe a idea of your setup could help: Audirvana version, macOS or Windows, usb dac (which one?), network player …?
Hello,
Audirvana ist installed on a Mac mini.
My dac is project pre box rs digital.
Streaming is on Master in audirvana.
I Look forward for our Information.
Thank you
Your dac is not MQA capable, how is set MQA capability in Audirvana dac settings? Which version of Audirvana do you have installed?
Please send me a copy of the “Debug Info”? You can get it in Audirvana Settings>General>Debug Info
Note: By clicking on the Debug Info button, Audirvana automatically copies all its content, all you have to do is paste it in response to this messag
Try download Tidal music to local using AudFree Tidal music converter and then play on Audirvana. It can preserve the original sound quality of Tidal. This way you can check if the problem comes with Tidal or Audirvana.
Hello @kellyken, are you aware that this type of software break the DRM of Tidal and it’s a piracy software? Please do not promote this type of content on the forum please.
