It is my experience that once a star is selected, you cannot reset them to zero stars. If I am wrong, can you please tell me how to do that?
Paul
If I don’t mistake select the first star again …
Thank you for the reply Stefano but that only selects the first star. I’d like to know how to have zero stars again.
Paul
Click on the first star and move the mouse to the left, this will work (just tried)
Thanks you. That worked perfectly!
