After I purchased Fidelizer, I wanted to connect Audirvana to Fidelizer. For that I needed the file Audirvana.exe, I read.
After a lot of puzzling, I managed to open the folder WindowsApps.
Unfortunately, the file âAudirvana.exeâ was not present in any of the Audirvana folders.
Does anyone have a solution for this problem?
Greetings, Cornelis
Hi Cornelis,
You can find the path+filename of any running program in Windows as follows:
Start Audirvana and after that open Windows Task Manager (right click on the Windows status bar and click âTask manager/Taakbeheerâ). In Task Manager right click on âAudirvanaâ and click on âopen file locationâ
âOpen file locationâ shows the Windows File Explorer with the location of Audirvana.exe:
You can copy the pathname from File Explorerâs title bar and paste it in Fidelizer (+ â\Audirvana.exeâ) to start Audirvana automatically by Fidelizer.
Edit: If you donât see the full path name in File Explorer make sure you have the following settings right in File Explorer (Click the 3 dots\options and after you changed settings then click the button âApply to Foldersâ:
Hi Andy,
Thanks a lot for your quick response.
I am currently on vacation, but as soon as I get home I will follow your instructions and let you know if it worked. Thanks a lot in advance.
Greetings, Cornelis
you dont need snakeoil apps mate, just use your player.
Hi Andy,
Immediately after I got home from vacation, I turned on the computer.
Thanks to your instructions, choosing Audirvana as a media player was a piece of cake. Thanks again.
Greetings, Cornelius
