Hi, I am using Audirvana Plus version 1.2.10(1050) trial version, ifi nano iOne Dac (with firmware version 5.30) and Schiit Audio Valhalla 2 Amp. I have set my Dac as MQA Renderer. Signal polarity invert globally disable, invert for tracks with inverpolarity comment disable. Upsampling set to device maximum frequency, all slides bar set to maximum.
The static noise can be heard throughout the tracks, I have tried different MQA tracks, all with same result. Any advice on my settings which I might have done wrongly.
Thanks.
